1997 Pontiac Firebird
67,000 MILES • 6 CYL • 2WD • AUTOMATIC
DEAN4321
way does a car smell like gas when you turn it off and I cant fine no leaks
Sep 10, 2009 at 8:04 AM
JDL
  • 16,098 POSTS
I'd check the injectors and fuel pressure regulator for leaks. If there is a vacuum line connector to regulator, check the line for gas.You might also use a fuel pressure gage, see if the system will hold pressure.
Sep 10, 2009 at 8:24 AM
  • 75,988 POSTS
Also check the charcoal canister could be saturated with fuel
Sep 10, 2009 at 10:03 AM
