1996 Pontiac Firebird Oil In Radiator
1996 PONTIAC FIREBIRD
127,000 MILES • 6 CYL • 2WD • MANUAL
ONTOMUCH
Yesterday while I was driving I noticed an sudden raise in my cars temp. She normally runs at a cool 140 and then all of a sudden it was at 180 this was very unusual so I brought her home and parked it. Then this morning I went to check the water level in the radiator and discovered a crap load of oil in the radiator so I know this is normally a sign of a blown head or a Head gasket but what I need to know is how do I find out what side is blown with out having to take off both heads and looking at them like that. and since there is so much oil in the radiator is the block still going to be ok? I mean it will start and run ok but I'm afraid that this oil in the coolant is going to screw the motor all up. is there anything I can do or should I replace the motor????
Thank you for your response
Tina
May 1, 2008 at 5:50 AM
  • 31,937 POSTS
Hi there,
You will have to do both heads, just to make sure, i don't think you would want to pull a head a second time. get the radiator cleaned & flow tested, flush oil as much of the dirty coolant as you can, a small amount in the cooling system wont be a problem.
mark (mhpautos)
May 1, 2008 at 10:58 AM
