1996 Pontiac Firebird COLD IDLE PROBLEM
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
BACKSNAPS
The engine will rev up to 3000 rpm when its cold. will not resume normal idle spped untill the engine is warm and the ignition is turned off then restarted. any help would be appreciated.
May 8, 2010 at 6:16 PM
  • 75,988 POSTS
Clean out the idle air control valve and see what happens.
May 11, 2010 at 3:23 PM
