1996 Pontiac Firebird car continues to sputter and lose som
1996 PONTIAC FIREBIRD
146,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANGELACHISAMORE
I RECENTLY REPLACED ALL 3 COIL PACKS, PLUGS, WIRES, AND THE THROTTLE POSITION SENSOR WHICH WAS SHOWING TO BE THE PROBLEM WHEN PUT ON THE COMPUTER. HOWEVER, AFTER ALL OF THIS WORK, MY CAR IS STILL SPUTTERING AND LOSING POWER. MY CHECK ENGINE LIGHT IS NOW BACK ON AS WELL. ANY SUGGESTIONS TO WHAT IT COULD BE??? I ALSO HAVE THE ABS LIGHT ON NOW THAT SAYS ABS INOP. CAN U TELL ME WHATTHIS MEANS?? I KNOW IT HAS TO DO WITH MY BRAKES, BUT I AM UNSURE WHAT THE INOP STANDS FOR.
Sep 11, 2009 at 6:04 AM
  • 110,244 POSTS
Inop means the ABS system isn't functional. Your brakes will work, but the ABS will not.
Have you checked to see if the catylatic converter is plugged?
Sep 24, 2009 at 4:44 AM
