1996 Pontiac Firebird car
1996 PONTIAC FIREBIRD
88,000 MILES • 4 CYL • 2WD • AUTOMATIC
SAL951
when my car is in park it sort of jumps and shakes the car. and when i put it in drive it has trouble accelerating and it also jumps. i already replaced the fuel filter and put some fuel injector but it didint help att all. and the check engine light is always on
Feb 11, 2009 at 9:18 AM
LTKNT
  • 30 POSTS
How long has it been since the car had a tune up? Spark plugs/wires/coils could be bad. If the check engine light is on, there is a trouble code(s) stored in the PCM (Computer) memory. Reading the trouble code should give you a good idea of whats causing the problem. If you don't have a reader, you can take the car to Auto Zone and the guys there can read the codes free of charge. Good Luck!
Feb 13, 2009 at 7:39 AM
