1995 Pontiac Firebird White Smoke and overheating
1995 PONTIAC FIREBIRD
94,827 MILES • V8 • 2WD • MANUAL
MATTAMAYA91
My 1995 Pontiac Firebird Trans Am is burning coolant in the engine and it is coming out the exhaust. Big clouds of white smoke and when enough coolant has been burned it overheats. First thing that comes to mind is blown head gasket or a cracked head. Right? Well my question is could it also be a intake manifold gasket?
Jul 11, 2008 at 4:12 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
Yes you could have a bad intake manifold gasket. It would still be a good idea to check your head gaskets. If you are burning oil too then most likely you have a failed head gasket. I have heard that dexcool is very hard on these materials.
Jul 11, 2008 at 4:53 PM
