1995 Pontiac Firebird no pwr at harness plug on ac/heater b
1995 PONTIAC FIREBIRD
139,000 MILES • 6 CYL • 2WD • AUTOMATIC
GEARHEAD454
I got a problem with the control panel. Theres no power at harness plug on blower motor speed control switch. fuse good. Put 12v. To back of harness plug only works on high speed. No low or medium speed. Could the AC/heater control module be the problem? . And is it the little black box with wire connector.in front. and wires coming out of box going into heater core box.?? How do I check to see if module is good. Thanks. Gh454.
Nov 9, 2010 at 4:58 AM
JDL
  • 16,098 POSTS
Did you check for voltage at the heater fuse, key on?
https://images.2carpros.com/forum/automotive_pictures/170934_firebird_heater_one_1.jpg
https://images.2carpros.com/forum/automotive_pictures/170934_firebird_heater_2_1.jpg
Nov 9, 2010 at 5:20 AM
