1995 Pontiac Firebird Help!!!
DARRELLJ
Computer problem
1995 Pontiac Firebird 6 cyl Front Wheel Drive Automatic
Okay... so first,
My car stopped working out of nowhere one day. I would turn the ignition and nothing would happen but the security light would flash.
Then I was was told that my Theft Deterrent Relay (TDR) may have been bad. So I was told to bypass it. (Joining the yellow and purple wires). That only allowed my ignition to start and not my fuel injector.
So then I tried to replace the TDR and that made the car make a weird noise. So I scrapped that idea and tried to replace the Theft Deterrent Module (TDM). After doing that, my car still did not start.
Did I do something wrong? Please help me fix this issue as this is my only car.
Thank you so much!
Darrell
May 21, 2010 at 10:52 AM
BLUELIGHTNIN6
  • 16,542 POSTS
what was the weird noise coming from? maybe the starter motor area ? the ignition switch or starter solenoid need checked.
May 21, 2010 at 4:59 PM
DARRELLJ
It sounded like it was coming from the Theft Deterrent Relay oddly enough and when I touched it, it was vibrating..... but the ignition works. The cars' just not getting the signal to pump fuel from the TDM. Is there any way I can reprogram my Theft Deterrent Module to send the signal to the fuel enable?
May 21, 2010 at 9:56 PM
