1995 Pontiac Firebird Fuel pump
DORCHIDS
Electrical problem
1995 Pontiac Firebird 6 cyl Wheel Drive Type unknown Manual 100000 miles
Greetings,
We replaced the fuel pump, however, now there is no power at the fuel pump. You can jump a wire from fuel pump to battery and it will start right up. What did I overlook??? Would removing alrm system be the cullprit? Thanks for any suggestions.
Dec 14, 2007 at 3:52 PM
ARTMANG
  • 61 POSTS
check to see if the pump fuse did not burn.its in the engine compartment in the 1 of the fuse boxes ,i says fuel pump and possible that it may have 2.one insed the fuse box also
Dec 30, 2007 at 2:22 PM
