1995 Pontiac Firebird Engine Missing
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
DIRTRACKFAN
I have a 95' P.F.B. with a 3.4l V6. When i got the vehicle it had a miss. It sat for 2 years with old fuel. I pumped it down and replaced with a full tank of 93 octane and a can of Sea Foam. I changed the fuel filter, plugs, wires, and oil filter. No luck with that. I had it scanned and the only code was MAP sensor, changed that, no luck.
The missing only happens under load if you "put your foot in it ", just over normal acceleration. You can "dry rev" it with little hesitation.
Feb 21, 2009 at 11:39 AM
OBXAUTOMEDIC
  • 3,718 POSTS
[quote:ba7abb03e7="dirtrackfan"]Engine Performance problem
1995 Pontiac Firebird 6 cyl Two Wheel Drive Automatic 130000 miles
The missing only happens under load if you "put your foot in it ", just over normal acceleration. You can "dry rev" it with little hesitation.[/quote:ba7abb03e7]
Check Compression and for Vacuum Leaks...
Feb 21, 2009 at 11:57 AM
DIRTRACKFAN
All cyl are pretty equal and I sprayed the running engine with starting fluid with no reving.
I forgot to mention that it has a cold air K&N with no air box. I do not see a MAF sensor and called the dealer and they said that there is not one on this vehicle.
Feb 21, 2009 at 12:36 PM
OBXAUTOMEDIC
  • 3,718 POSTS
Have you check the Fuel Pressure? Specs are 41 - 47 psi.
Check out this video for testing proceedure...
https://www.2carpros.com/dia/test_fuel_pressure.htm
Feb 21, 2009 at 1:49 PM
