1995 Pontiac Firebird computer?
101,000 MILES • V8 • 2WD • AUTOMATIC
THE BIG RED ONE
  • 11 POSTS
I recently replaced the distributor and water pump.That was after I took it to a shop and was charged $558.00 to have the plug wires changed.The distributor and water pump I changed myself because 2 weeks after the wires were changed I took the car on the freeway for about 10 miles and the car started to run as bad as it did before I changed the wires.I took the car to another shop and they told me one of the wires had grounded out on the exhaust manifold.They also changed the plugs that had been changed when I first changed the wires.The mechanic made the statement that he thought that something with the computer might be going on as all the plugs seemed to be fuel fowled.They had only been on the car for about 2 weeks.Any ideas about what he could be talking about or any ideas on what I should check next?
Jul 11, 2009 at 5:25 PM
BMRFIXIT
  • 19,053 POSTS
I had seen some where the system was running rich
due to a bad coolant sensor and or MAF sensor
are you getting a check engine light on ?if so get the codes
check and clean MAF sensor
also an O2 sensor might do it
have to use a scanner if possible to diagnose what is happening
take a look at fuel regulator if leaking
pull vacuum hose off of it and check for fuel
Jul 11, 2009 at 11:59 PM
