1995 Pontiac Firebird Car Turning Signal Blinkers
128,288 MILES • 6 CYL • 2WD • AUTOMATIC
M-80KLUTCH
I have a 1995 Pontiac Firebird 3.4 V6 automatic. I recently replaced my ignition lock cylinder because my car was not starting up. This fixed my problem with starting the car up, but now my blinkers will not turn on. Could i have just put a wire back in wrong or could I have blow something?
Feb 24, 2010 at 3:54 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating!
First thing is to check out the fuse for the signals. Very possible that you may have accidentally unplugged the turn signal switch connector or plugged it in the wrong spot (not likely since most connectors only plug in one way) during repairs though. If fuse is OK you will have to inspect the wiring at the repair you made.
Feb 24, 2010 at 4:08 AM
