1994 Pontiac Firebird LIGHTS WILL NOT CLOSE
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
MILLER00
I TURNED ON THE HEADLIGHTS AND THEY OPENED UP, BUT WHEN I TURNED THE HEADLIGHTS OFF BOTH LIGHTS STAYED OPEN. WHEN I LISTEN I CAN NOT HEAR THE MOTOR ON THE HIDE AWAY LIGHTS RUN AT ALL. I CAN NOT FIND THE FUSE TO CHECK BUT I CHECKED ALL THAT I FOUND AND FOUND NOTHING. CAN YOU PLEASE HELP.
THANK YOU
DARRELL
May 9, 2010 at 1:21 PM
INTERNETMECHANIC
  • 700 POSTS
I suspect the headlamp door module. Two wires at lamp door motor, voltage and ground, reversing motor, the circuits switch, depending on whether the door is opening or closing. You can check circuits, if you want?
https://images.2carpros.com/forum/automotive_pictures/512072_firebird_headlamp_door_module_1.jpg
https://images.2carpros.com/forum/automotive_pictures/512072_firebird_lamp_door_module_circuit_1.jpg
The blue wires are for one lamp door motor. The green wires are for the other.
May 10, 2010 at 2:08 AM
