1994 Pontiac Firebird Knock Sensor
1994 PONTIAC FIREBIRD
158,000 MILES • 6 CYL • 2WD • AUTOMATIC
PONTIACMAN22
When ever i start the my car it idles rough and when i put in gear and start moving it starts shaking a lot and then it stops shaking and goes back to normal. Although at idle theres a knocking noise in the upper right side of the engine could my knocking sensor be bad ?
May 30, 2010 at 11:26 AM
BLUELIGHTNIN6
  • 16,542 POSTS
have you checked the engine oil level? if oil level is good might wanna check oil pressure
May 30, 2010 at 3:40 PM
