1994 Pontiac Firebird fuel pump
1994 PONTIAC FIREBIRD
100,000 MILES • V8 • 2WD • AUTOMATIC
SMITTY28
fuel pump kicks in but wont turn over,cant find a reset button is there one.thought might be IMCS,cant locate it.
Oct 4, 2010 at 12:27 PM
BLUELIGHTNIN6
  • 16,542 POSTS
are you certain it is a fuel issue? if fuel pump is coming on then check fuel pressure. just because it is on doesn't mean its pumping good. there is no reset switch .
Oct 4, 2010 at 1:20 PM
SMITTY28
it will fire up with a shot of starter fluid,could it b the ICMS?fuel pump kicks on till u go to start then nothing.i checked to c if the wires r hitting the were fine good spark of the motor.
Oct 5, 2010 at 8:15 AM
BLUELIGHTNIN6
  • 16,542 POSTS
fuel injectors may be stuck or could be computer not telling injectors to open
Oct 5, 2010 at 10:42 AM
