1994 Pontiac Firebird fuel pressure regulator
1994 PONTIAC FIREBIRD
STURGELL
Engine Performance problem
1994 Pontiac Firebird 6 cyl 145000 miles
i think ive got the car diagnosed with a bad fpr it is running with 20-22 psi when it should be at 41-47 pressure holds steady after key is off and i pulled the vaccume line off the fpr while running and had no raise in pressure so my question is this does this sound like the problem and if so do i have to pull the fuel rail in order to fix it. they do not sell fpr's for this car just a rebuild can this be done from the top?
Oct 24, 2008 at 8:55 AM
Hi sturgell and welcome to 2carpros
Sounds to me you nailed it-the pressure should increase about 8lbs or better from the vacuum regulated reading-it could be done with patient
Oct 24, 2008 at 9:06 AM
