1994 Pontiac Firebird changing water pump
1994 PONTIAC FIREBIRD
LARRYVINES
Engine Cooling problem
1994 Pontiac Firebird 6 cyl Two Wheel Drive Automatic
i am attempting to change water pump on 94 v6 firebird unable to get 1 bolt out, does the power steering pump have to be removed in order to make the repair? Or do you have any advice, please help.
Nov 4, 2008 at 6:25 AM
KEVIN12881
  • 336 POSTS
for a v6 (3.4l only) you need to unbolt and move the power sterring pump bracket and one coil of the coil pack
Nov 18, 2008 at 8:47 PM
