1994 Pontiac Firebird blinkers
1994 PONTIAC FIREBIRD
15,000 MILES • 6 CYL • 2WD • AUTOMATIC
XFADETOBLACKX84
my blinkers didnt work for the longest time. they would just stay lit up. i would signal left and the arrow would stay lit up on the dash and outside the car, but they wouldnt flash. same thing for signaling right. i changed the flasher relay and now the left flashes but very slowly and the right does the same thing it had done before, just stays lit up. what could the problem be? and the bulbs are fine.
Feb 13, 2009 at 8:41 AM
MIKE H R
  • 3,094 POSTS
check the wiring and sockets. sometimes the do not make proper contact. also check the gorund wires. My wifes 95 firebird did the same thing and I found out it was some corrosion in the light socket.
Feb 15, 2009 at 3:25 AM
