1994 Pontiac Firebird
RHONDA3
  • 1994 PONTIAC FIREBIRD
  • 6 CYL
  • 194,268 MILES
My car is hard to start when cold (the first start of the day) I have to turn it a few times before it catches any ideas?
Thursday, October 28th, 2010 AT 9:59 AM
Check the fuel pressure if its within specs and test the coolant temperature sensor and clean out the idle air control valve and see what happens
Thursday, October 28th, 2010 AT 10:12 AM
WRENCHTECH
  • 20,761 POSTS
The first things to test are the fuel pressure and compare it to the spec and use a scan tool to look at the temp sensor readings for both ECT and IAT before starting it.
