1994 Pontiac Firebird
ARIZONAATCHLEY
Brakes problem
1994 Pontiac Firebird V8 Automatic
Brakes are not working. Pedal hits the floor. If I push hard and use the parking brake I can stop the car. What is the damage?
Mar 21, 2010 at 12:39 PM
  • 110,248 POSTS
Either you have a blown brake line / hose, caliper, wheel cylender, or the master cylender is bad. Check under the vehicle for evidence of fluid leaks. If the master cylender is full of fluid and doesn't lose any, then it is bad. If there is a leak, the Master cylender will need to be refilled.
Let me know what you find.
Apr 19, 2010 at 6:37 AM
