1993 Pontiac Firebird turning signals
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
ZAC123
The turning signals are not working. I have replaced the flasher but they still do not work. Also I have checked all the fuses and they are all good. The parking lights do work. When I step on the break with the left turn signal on the left break light goes out. Same goes for the right side. What is the Problem and how can I fix it.
Dec 4, 2009 at 3:27 AM
  • 75,988 POSTS
Check and test the turn/hazard switch the turn and brake circuit goes thru this switch
Dec 4, 2009 at 3:36 AM
