1993 Pontiac Firebird trans am axle
99,000 MILES • V8 • 2WD • AUTOMATIC
JEN27
I am working on putting a new pinion gear in my 1993 pontiac firebird trans am. I cannot figure out how to pull the axles apart to get to it
May 17, 2009 at 3:53 AM
MIKE H R
  • 3,094 POSTS
there are four bolts that hold the axle in place. remove the bolts then there is a slide hammer puller used to remove each axle.
May 17, 2009 at 4:11 AM
JEN27
we have got the bolts off and loosened the slide hammer but it feels like its stuck what should we do
May 17, 2009 at 4:29 AM
MIKE H R
  • 3,094 POSTS
some axles hace a C lock. Look at the end of the axle inside the pumpkin. the pinion shaft will have to be removed so the shafts can move inward making the c locks accessible to be removed. once you get the c locks removed then you will be able to use the slide to remove the axle.
May 17, 2009 at 4:43 AM
