1993 Pontiac Firebird fuel pump cycles for 2 seconds no fue
1993 PONTIAC FIREBIRD
128,765 MILES • V8 • 2WD • AUTOMATIC
93TA
yes i have a 1993 firebird and the car stopped on the way home i tested spark it was fine, then checked for fuel flow at the rail no fuel, this led me to the fuel filter i then replaced the filter but i still do not get fuel flow to the engine, i can hear the fuel pump cycle on with the ignition but then stop after a few seconds. took the pump out the screens are clean but the flex hose to the pump was broken in half i replaced that, still no fuel to the fuel filter. any ideas
Nov 28, 2008 at 2:36 PM
Still no fuel pressure-you sure you hook the hoses back correctly if so replace the fuel pump
Nov 28, 2008 at 2:41 PM
93TA
i disconnected it at the fuel filter to see if fuel would flow through the line still nothing. i thought the line may be clogged took it out blew it out hooked back up nothing. can the fuel pump actually cycle and not send fuel out the line?
Nov 28, 2008 at 3:00 PM
Replace the fuel pump
Nov 28, 2008 at 3:16 PM
