1993 Pontiac Firebird ECM codes
STEWMAN1955
Computer problem
1993 Pontiac Firebird 6 cyl Two Wheel Drive Automatic
cannot get codes to flash using a code reader what causes this
Jun 28, 2010 at 1:09 AM
BLUELIGHTNIN6
  • 16,542 POSTS
are you using correct scanner? should use a OBD I style scanner. also make sure cigar lighter fuse is good.
Jun 28, 2010 at 4:29 AM
