1992 Pontiac Firebird 6 cyl Two Wheel Drive Automatic
1992 Fire bird 3.1. Engine started lossing power under load. Problem kept getting worse untill no power. Car then needed to be towed. Engine then would only run at idel and would stall when reeved.
Now engine only wants to start when full throtle but wont run or idle. Is this a fuel pump / filter problem.
Or is this a sensor problem. Note no engine light at this time. Thanks Jim
SPONSORED LINKS
Monday, February 9th, 2009 AT 5:54 PM
