1992 Pontiac Firebird crankshaft position sensor location
1992 PONTIAC FIREBIRD
133,000 MILES • 6 CYL • 2WD • AUTOMATIC
92 3.1 FIREBIRD
hi, i have a 1992 3.1 Liter firebird, will crank but will not start i replace evrything from the fuel pump to the distributor and between. I wanted to know if u could tell me where to find the crankshaft position sensor? If u could send picture to desmith316@yahoo.com, or tell what component to find this by,or under i would appretiate it very much!
Aug 4, 2009 at 7:46 PM
JDL
  • 16,098 POSTS
Hello, you don't have a crank-shaft position sensor. Have you done any basic testing? Have helper crank it, while you check for spark at the plugs? Primary voltage to the coil is pink wire, goes hot when you turn on the key.
Aug 5, 2009 at 1:01 PM
92 3.1 FIREBIRD
yes ive checked spark, it is fine, but i got a new fuel pump and i dont think its putting out enough psi? The car has been sitting for 6 years and ive replace whole fuel system and spark plugs, distributor, distributor cap, alternator, the car still wont run... i dunno what to check next?
Aug 5, 2009 at 4:59 PM
92 3.1 FIREBIRD
i have also replaced the coil, and cleaned out the injectors.
Aug 5, 2009 at 5:01 PM
JDL
  • 16,098 POSTS
Check fuel pressure 40--47psi, key on engine off. Also check for an injector pulse, engine cranking.
Aug 6, 2009 at 8:31 AM
