1992 Pontiac Firebird coolig fan wont run
1992 PONTIAC FIREBIRD
133,000 MILES • 6 CYL • 2WD • AUTOMATIC
RETAILMAN
Hi, i bought a new ecm, or ecc module, but my cooling fan ran at the right time before i bought it. Now it doesnt run and i was wondering if anyone knew anything about it?
Sep 4, 2009 at 2:02 PM
BLUELIGHTNIN6
  • 16,542 POSTS
have you reprogammed the new ECM that was installed? was this ECM a brand new item or a used item from a different vehicle?
Sep 4, 2009 at 3:19 PM
RETAILMAN
no this ecm is for this vehicle, and is new from a autozone store. But i took the chip out of the other ecm and put it into the new one, so it should have the same programable memory?
Sep 5, 2009 at 11:28 AM
BLUELIGHTNIN6
  • 16,542 POSTS
ok. have you already inspected the fuse and the cooling fan relay ? does the fan come on with the A/C (if equipped) switched on ?
Sep 5, 2009 at 5:26 PM
RETAILMAN
no the cooling fan does not come on if i turn the a/c on.Yes i checked the fuse and its a.o.k. When i hook my actron code reader in, the fan kicks on.
Sep 6, 2009 at 2:00 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Since the basics have been tested OK, you will need to perform the following tests to determine the cause of this issue.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_940.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_255.jpg
Sep 7, 2009 at 4:05 AM
