1991 Pontiac Firebird Transmission Leak
209,000 MILES • 6 CYL • 2WD • AUTOMATIC
LFLEM88
My 1991 Pontiac Firebird is leaking transmission fluid at a stream whenever I turn the car on. I can not see exactly where the leak is coming from because it's sort of streaming from the front of the pan. Will I have to get a new transmission or Can I get it sealed? How much will either cost?
Apr 5, 2008 at 8:25 AM
KEVIN12881
  • 336 POSTS
You can replace the filter wich comes with the gasket for about $30. It has to be leaking from the pan. To rebuild the trans... about $1,400!
Apr 20, 2008 at 12:25 PM
