1991 Pontiac Firebird stumbles & dies after it has warm
139,000 MILES • 6 CYL • 2WD • AUTOMATIC
TEPE
The engine stumbles & dies after it warmes up. It has new plugs,wires, cap, rotor, modual, coil, fuel pump, fuel filter. I took the EGR off & it still acted the same way.
Sep 18, 2009 at 3:03 AM
  • 110,248 POSTS
Has the check engine light come on? HAve you checked the crank sensor? If you had the EGR off, that would have created a large vacuum leak. How did you check it?
Sep 24, 2009 at 3:51 AM
