1991 Pontiac Firebird started running ruff
41,000 MILES • V8 • 2WD • AUTOMATIC
MARK ROBERTS
For a car that has this low of milage I have had to do all kinds of things to it, I call it GMs junk.
Never the less, the engine was serging with rpms, before I tuned it up, if idling would run up and down from 700 to 2000 on the tach. Ok I did a tune up, noticed with the original distrubitor had a lot of carbon build up and rust, bought oem replacement, and a good brand of rotar with new cap, plug wires (9) mm, and a set of mgk plugs, gapped to specks, after I timed the engine to 1 degree btdc as specified. Engine cranked quick and easy, but the idle still hesitant, light accleration would go into a stall, more accleration would launch, full accleration acked like some plugs were missing out. Ok back to auto store, changed out Idle control valve, and egr valve. I don't mind spending the money I just want to get to the problem and get it right, fuel injection is a totally different ball game, and I don't want to waste much money unless have to. All vaccumm lines are replaced, the engine has no leaks, runs quite, just having accelator problems, and now it's hard for it to stay running at idle, simply you have to play with the gas peddle. I counted about 6 more sensors to go, should I purchase everything excluding the throttle body, and that's around $340.00. If your experienced with these 305 engines maybe you know this problem, and could help me out. I thank you for any response. Thanks, Mark Roberts
I don't know how much to donate, how much do you want?
Jul 27, 2009 at 3:57 AM
  • 75,988 POSTS
I don't know how much to donate, how much do you want? Any amount as you wish.
Okay lets try below and get back with me with some results so I can analyze it and lead you to the right direction-Your shot
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation/surging/stumbling/jerking is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Jul 27, 2009 at 11:07 AM
