1991 Pontiac Firebird headlights
11,000 MILES • 6 CYL • 2WD • AUTOMATIC
AL HOWES
car has been sitting in my garage a couple of years,engine runs ok,but have no head lights(headlights are retractable,but they don't work either,also no dashlights, no dome light, and the rear hatch doesn't lock down
May 29, 2009 at 12:39 AM
JDL
  • 16,098 POSTS
Hello, do you think gremlins might have got at some of the wiring circuits? There should be circuit breakers for the hdlmp doors, I'd check voltage feed to the breakers.
You can also get at the connector for the headlamp switch, check the feed to and from the switch.
May 29, 2009 at 2:13 AM
