Remove the spark plugs and check
is it running rich
check fuel pressure regulator
also I would do a fuel pressure test
also do a fuel leak test
turn key on and what your reading turn key off and check the reading is it going down fast
u have a leak
check injectors and fuel regulator
good luck
SPONSORED LINKS
Saturday, September 13th, 2008 AT 6:53 AM
