1991 Pontiac Firebird engine runs rough
150,000 MILES • V8 • 2WD • AUTOMATIC
CHEFBEAURD
I have to press the gas halfway down for the rpm to go up and for the car to start moving.Sometimes it doesn't start moving until i hit the gas all the way down and then all of the sudden the rpm will shoot up to about 3000. sometimes when i hit the gas it chugs really hard and sometimes it dies.When it is in nuetral I get a quick throttle response but when it is in gear it runs bad.had it in 3 shops and they told me its running fine?!?!?!
Mar 14, 2009 at 2:23 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:9000b1b898="chefbeauRD"]1991 Pontiac Firebird V8 Two Wheel Drive Automatic 150000 miles
I have to press the gas halfway down for the rpm to go up and for the car to start moving.Sometimes it doesn't start moving until i hit the gas all the way down and then all of the sudden the rpm will shoot up to about 3000. sometimes when i hit the gas it chugs really hard and sometimes it dies.When it is in nuetral I get a quick throttle response but when it is in gear it runs bad.had it in 3 shops and they told me its running fine?!?!?![/quote:9000b1b898]
Sounds more like a tranny problem. Check tranny fluid. Is engine light on? if so need to pull codes.
Mar 14, 2009 at 3:26 AM
