1991 Pontiac Firebird
1991 PONTIAC FIREBIRD
91FIREBIRD08
Electrical problem
1991 Pontiac Firebird 6 cyl Two Wheel Drive Automatic
where can i find the reset button on my car
Jan 26, 2010 at 3:22 AM
JDL
  • 16,098 POSTS
Welcome, A reset button for what? If the vehicle cranks good but won't start, have a helper crank it, while you check for spark at the spark-plugs. If you have spark everywhere, use a gage and check fuel pressure. Some of the national brand autostores might loan you a fuel pressure gage. You can all and ask? Are there any trouble-codes? How long since a tune-up? I need more info.
Jan 26, 2010 at 7:41 AM
91FIREBIRD08
[quote:6075eae991="jdl123"]Welcome, A reset button for what? If the vehicle cranks good but won't start, have a helper crank it, while you check for spark at the spark-plugs. If you have spark everywhere, use a gage and check fuel pressure. Some of the national brand autostores might loan you a fuel pressure gage. You can all and ask? Are there any trouble-codes? How long since a tune-up? I need more info.[/quote:6075eae991] i got a 91 firebird an i was driving it and it ran out of gas. i got it to a gas station and filled it up but it won't start. it gets fuel and it cranks and thats about all it does..
Jan 28, 2010 at 12:14 PM
JDL
  • 16,098 POSTS
Sorry for the late reply. Had ice storm in my state, electricity was lost on thursday, just got it back.
I don't know how to help, unless you can do some testing? You can check for spark at the plugs. Pull plugwire loose, stick known good plug or tester in the boot, ground tester or metal part of plug to metal part of engine. Have helper crank it, while you watch for spark at tester or plug. Go from there.
Jan 30, 2010 at 4:41 AM
