1990 Pontiac Firebird please help me
1990 PONTIAC FIREBIRD
RGIBSON85
Engine Mechanical problem
1990 Pontiac Firebird 6 cyl Automatic
hello my name is Randy Gibson and i have a problem, my 1990 firebird is not starting right, or when it does start it will shut off right away. there is no cranking or noises i think that there is no gas getting to my engine. I have spark, and i have fuel pressure "42lbs" I just bought a new computer under my dash and installed it but that wasnt the problem, and i just bought a new modual but that didnt fix it either. i think it has something to do with my injectors..... please tell me how to fix this.
Thank you so much
Jul 18, 2009 at 10:36 AM
Do you hear the fuel pump come on when you turn key to run position? If so check the fuel pressure if its within specs-check for injection pulses. If you don't hear the fuel pump-check the fuse and fuel pump relay.
Jul 18, 2009 at 10:58 AM
