1990 Pontiac Firebird Iginition Module
ROGEREW
Electrical problem
1990 Pontiac Firebird V8 Two Wheel Drive Automatic
What would cause an ignition module to go out in a short period of time after replacing it?
It is 355 CI TPI blown 9 PSI Motor with Crane ignition system. Header and all the goodies
Dec 5, 2008 at 5:18 AM
BUDDYCRAIGG
  • 2,262 POSTS
if you didn't put the heat transfer grease under the module.
or i've seen failing coils kill modules pretty quick too.
Dec 14, 2008 at 12:55 PM
