1990 Pontiac Firebird Engine runs horrible
1990 PONTIAC FIREBIRD
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
JIMMY53158
Hi I have a 1990 firebird with a 3.1L and have been having problems with it backfireing and not wanting to accelerate when warm. I've replace the cap 3 times because it was corroted but this time it isn't and I have chaged the rotor, fuel filter, spark plugs and wires. Don't know what else to do HELP PLEASE!!!! Also when it is running somewhat decent and I take off to fast it makes a hard hitting noise that sounds like the rear end is going to break off.
Aug 18, 2009 at 3:34 PM
JMALECKI
  • 118 POSTS
Hello
a couple of things to check, firing order and timing if those check ok you may have a bad valve but check those basics first.
John
Aug 22, 2009 at 9:27 PM
