1990 Pontiac Firebird
WYHOTTIE
Shakes or Wobbles problem
1990 Pontiac Firebird V8 Two Wheel Drive Manual
when i am driving down the road my car floats back and forth even at a low rate of speed its in the front end exspecially when i turn a corner
Jan 14, 2009 at 5:54 PM
KEVIN12881
  • 336 POSTS
check the wear on your tires
Jan 16, 2009 at 12:02 PM
FIRST TIME FIREBIRD
could be the sway bar and/or the stabilizer links.
Jan 30, 2009 at 4:36 AM
WHITESTONE
  • 6 POSTS
Toe out (not enough toe in) can cause floating side to side
You can check this yourself if the tires are near new(good deep tread grooves) ---
just pick a grove and measure from left front tire to right front tire as far forward on the tire as you can and still have a straight line for the tape measure.
then measure as far back on the front tires as you can - make sure you use the same grooves on the tires as the first measurment.
The measurement in back should be slightly larger than the front.
If it is the same or smaller then you need to adjust by adjustinf the front tie rods.
Feb 2, 2009 at 12:35 PM
