1989 Pontiac Firebird headlights wont tunr on.
75,000 MILES • V8 • 2WD • AUTOMATIC
SKIDEL
I reciently went to drive my 89 firebird at night. when i hit the lights they did not turn on, so i turned them off and tried again, to no avail. I have replaced the fuse to the headlights and still nothing happens, i cant figure out why they wont turn on,
Dec 17, 2008 at 2:44 AM
MIKE H R
  • 3,094 POSTS
have you checked the relays under the hood.
Dec 20, 2008 at 3:56 PM
SKIDEL
Yes i have and they are all working fine, now they will turn on but will randomly turn off on me.
Jan 13, 2009 at 9:09 AM
MIKE H R
  • 3,094 POSTS
so after you pulled the relays and checked them, then replaced them the lights work at times? With them working at times now I would check the wiring by the relays. There could ber a corroded wire or loose wire.. Try turning the lights on and move the wires under the relays.
Jan 15, 2009 at 7:34 AM
