1989 Pontiac Firebird dies when warm
1989 PONTIAC FIREBIRD
WATERRYDER
  • 5 POSTS
Engine Performance problem
1989 Pontiac Firebird 6 cyl
after the car get warm it dies.I did a tune up on it but it still does in changed the control module its a 2.8 multi port injection motor
Oct 27, 2010 at 2:19 PM
Check the fuel pressure to rule out a failing fuel pump.
Does it start right back up or you have to wait?
Oct 27, 2010 at 3:03 PM
WATERRYDER
  • 5 POSTS
you have to wait until it cools a little
Oct 27, 2010 at 3:44 PM
Do below
Next time it refuses to start don't wait for it to make up its mind-do below immediately to determine if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Oct 27, 2010 at 4:24 PM
