1989 Pontiac Firebird
FASTCARS
Engine Mechanical problem
1989 Pontiac Firebird V8 Two Wheel Drive Automatic
hi, i have a 89 firebird with a ls1 engine,i have two probems 1-when engine is hot and you shut the car off it wont restart ,it cranks but wont start until it cools down 2-the car has a 500 rpm swing in park and coming to a stop,the car ends up stalling if i dont gas and brake /work that has been done-new plugs/wires/cap/rotor/fuel filter/fuel pump/idel air control valve.i bought the car this way so i dont know how long its been going on ,thanks for helping
May 21, 2009 at 7:00 PM
JDL
  • 16,098 POSTS
Hello, did you do any basic testing before replacing anything? When the vehicle refuses to start, have a helper crank it while you check for spark at the plugs. If that checks out, use a gage and check fuel pressure. Can you check for troublecodes?
May 22, 2009 at 2:09 AM
  • 110,248 POSTS
In addition to JDL213, has the check engine light come on? Also, like he said, if there is no spark, there could be a problem with the ignition module.
May 24, 2009 at 11:54 AM
