1988 Pontiac Firebird no ckeck engine light no spark
88NOTCHBACK
Electrical problem
1988 Pontiac Firebird V8 Two Wheel Drive Automatic 0
hi i have a 1988 pontiac gta 350 5.7 tpi just had the engine rebuilt put the car back together with all new parts and have no check engine light and no spark car has new distributor coil and new engine sensors car ran before engine was rebuilt and the vats system has been disabled have power to ecm and power to injectors no power to distributor and no check engine light please help thanks tom
Jan 14, 2009 at 5:27 AM
  • 75,988 POSTS
Inspect the distributor drive gear/test the pick-up coil and the ICM-power to the coil
Jan 14, 2009 at 8:37 AM
88NOTCHBACK
[quote:c409a9bc78="rasmataz"]Inspect the distributor drive gear/test the pick-up coil and the ICM-power to the coil[/quote:c409a9bc78] the distributor is brand new and it has a new pickup coil and icm tested both and and are fine, no power to the distributor at all and no power to check engine light
Jan 14, 2009 at 8:54 AM
