1988 Pontiac Firebird Need help with my door
1988 PONTIAC FIREBIRD
KNIGHTRIDER25
i recently bought a 1988 firebird and the following day i had it, the driver side door wouldn't open, i took the inside panel off and found that there was a piece missing that connects the door handle rod to the part that opens it, i was told that its a plastic clip or something that i needed to get, does anyone know what that part is called? hope this made sense
Feb 10, 2009 at 2:02 PM
MIKE H R
  • 3,094 POSTS
door actuator clip. it is made of plastic and goes on the actuator rod and holds it in place. if the door opened when you got it then the clip may just come off and be on the bottom inside the door
Feb 13, 2009 at 12:48 AM
