Engine Performance problem
1988 Pontiac Firebird V8 Two Wheel Drive Automatic
88 firebird has been converted to carb rather than injection. Engine hesitate under load, and diesels when shut down New plugs, wires, coil
Sunday, August 16th, 2009 AT 7:49 PM
MECHANIC
This is tough one because it isn't OEM. Have you checked for vacuum leaks? What type of fuel pump are you using, the original one? As far as the dieseling, how rich is the engine running, are you using good?
SPONSORED LINKS
Sunday, August 16th, 2009 AT 10:46 PM
DDMFFOOD
MEMBER
New fuel pump, no vacuum leaks are evident. It's running a little on the rich side, but if I back it off much more it stalls. Could the EGR valve cause this?
Monday, August 17th, 2009 AT 3:46 PM
DDMFFOOD
MEMBER
Also, it's now bucking pretty good when warm and stalling when warm. Starts right back up after stall.
Monday, August 17th, 2009 AT 3:48 PM
DDMFFOOD
MEMBER
Also, using an Edelbrock 650 four barrell carb is it possible this is not enough carb for a 350 ci motor. Fuel adjusters on carb wide open, fuel pressure reg just over 1/2 open. Any more and it floods. Any less and it stalls
Monday, August 17th, 2009 AT 9:03 PM
MECHANIC
Actually, the fuel pump is my concern. How much pressure is making its way to the carb? Also, yes a bad EGR could cause this too. Remove it and check if it for carbon build up and make sure the valve is sealing shut.
