1988 Pontiac Firebird dash light
1988 PONTIAC FIREBIRD
160,000 MILES • V8 • 2WD • AUTOMATIC
MASTERATARMS06
My 88 firebird when i turn on my head lights my dash lights so i can see my gauges does not light up. Fuses are all good, my check engine light and brake lights all come on just not the lights so i can see my gauges any ideas?
May 9, 2009 at 10:47 AM
MIKE H R
  • 3,094 POSTS
with your headlights working ok and everything else then the problem would be in the dimmer switch for the dash. If I rember you have a wheel type. with it being dark turn on the headlights and turn the dash dimmer switch up and down. If lights srtill don't go on then the problem will be in the dimmer switch itself. First check the wires going to the switch in the back. Have seen where a wire had become loose.
May 9, 2009 at 2:18 PM
MASTERATARMS06
dimmer switch for the dash is fine it will turn on the cargo light in the car and there were no loose wires either.
May 9, 2009 at 2:31 PM
MIKE H R
  • 3,094 POSTS
the cargo light has a seperate connection in the switch. when you turn it all the way then it connects another circuit to turn the light on.
May 9, 2009 at 2:34 PM
