1988 Pontiac Firebird blue smoke, black smoke,
150,000 MILES • V8 • 2WD • AUTOMATIC
MASTERATARMS06
I have a 1988 Firebird with 150000 miles. It is blowing black smoke when first fired up. Blue smoke when i lay on the gas. And when the car is at idle in park its fine when i put the car in drive my rpm's jump up and down. Plugs are new, wires are new, compression tested and was fine, no error codes displayed.
Apr 26, 2009 at 2:57 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation
Blue and black smoke indicates burning oil. Oil is leaking into the combustion chamber and being burnt out the exhaust. You will have to tear the engine down to inspect the internal parts. Worn piston rings would be the most common to cause this but there is no way to tell without inspecting engine internally.
Thanks for using 2CarPros.com!
Apr 27, 2009 at 12:04 PM
