1987 Pontiac Firebird Carb problem
1987 PONTIAC FIREBIRD
89,000 MILES • V8 • 2WD • AUTOMATIC
CAWOELKE
My check engine light has been on ever sence I got the car, I found a wire that goes to the carb and when I plugged it in the car quits but the light goes out on it. What would be the problem?
Apr 10, 2010 at 9:34 AM
  • 110,244 POSTS
If the check engine light is on, there is a code stored in the computer that will identify where the problem is coming from. Have the computer scanned. I believe it is an OBD1 which just requires you to jump two leads.
Apr 19, 2010 at 3:39 AM
