1987 Pontiac Firebird Car stops "pulling at 3k and pop
87BIRD
Engine Performance problem
1987 Pontiac Firebird Two Wheel Drive Manual
I have a Firebird with the 305 T.P.I in it has many new parts (I.E computer maf egr valve full tune up Ect Ect.)
Wen i start the car she will start to make a poping noise around 3k rpms the stop after about 45k rpms. But also when the car gets floored it will stop "Pulling at 3k rpms it will still gain speed but very slowly. It feels like the car is not advacing or something is holding it back. The car does advance fine(I hooked up a scanner to it.) So please ANY help would be great. No one can seem to figure out the problem. So this is a great shot to put your skills to the test.
Nov 3, 2008 at 8:40 AM
  • 75,988 POSTS
Have the fuel pressure, ignition timing, knock and throttle position sensors checked out to include a back pressure check on the exhaust system
Nov 3, 2008 at 9:58 AM
87BIRD
How would i check the back pressure of the exhaust and how many psi is my car running(On the fuel system ive heard 70 but am still not shure?)
Nov 3, 2008 at 10:45 AM
  • 75,988 POSTS
To check backpressure-use a 0-15psi pressure gauge and remove the oxygen sensor-the reading should be less than 1.5 pressure at idle not to exceed 3 psi
I'm unable to furnish the fuel pressure specs not in the Mit1 auto references, I'll keep trying though
Nov 3, 2008 at 11:19 AM
87BIRD
[quote:f79930fe4a="rasmataz"]To check backpressure-use a 0-15psi pressure gauge and remove the oxygen sensor-the reading should be less than 1.5 pressure at idle not to exceed 3 psi
I'm unable to furnish the fuel pressure specs not in the Mit1 auto references, I'll keep trying though[/quote:f79930fe4a]
So if does not have any back presshure that would be bad???
Nov 3, 2008 at 12:18 PM
  • 75,988 POSTS
So if does not have any back presshure that would be bad??? You're good to go with no backpressure
Nov 3, 2008 at 2:44 PM
  • 75,988 POSTS
Fuel pressure should be 38-48psi for TPI engine-
Nov 3, 2008 at 3:14 PM
87BIRD
[quote:c0f104cb8b="rasmataz"]Fuel pressure should be 38-48psi for TPI engine-[/quote:c0f104cb8b]
Cool thank you. I will hook up my fuel pressure gauge possibly tomorrow.
Nov 3, 2008 at 3:39 PM
