1986 Pontiac Firebird Spark
TABANDJEFF2000
Electrical problem
1986 Pontiac Firebird 6 cyl Two Wheel Drive Automatic
Does the brain control spark? We have replaced the following parts already coil, modular, distributor cap, new plugs and wires, crank sensor. And still no spark where do we go next?
Oct 12, 2008 at 3:30 AM
  • 75,988 POSTS
No spark normally an HEI problem-check the distributor pick-up coil resistances and short to ground
Oct 12, 2008 at 3:41 AM
TABANDJEFF2000
It is a new pick up coil.. can you please explain in more details on this how do you check for resistances and not sure what you mean by short to ground
Oct 12, 2008 at 3:49 AM
  • 75,988 POSTS
See below
https://images.2carpros.com/forum/automotive_pictures/12900_dist1_3.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_dist2_2.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_dist3_2.jpg
Oct 12, 2008 at 4:06 AM
