1986 Pontiac Firebird Electrical problems on newly bought c
160,000 MILES • 6 CYL • 2WD • MANUAL
GNAPPI
Both my A/C clutch and cooling fan work with DC applied directly, but not under operation. I have schematics but no physical locations for relays and fusible links. Could the problems be related? The schematic I have indicates NO.
Any help would be appreciated debugging these issues.
Sep 17, 2009 at 4:08 AM
DOCFIXIT
  • 18,828 POSTS
Do you have gagues? if yes check charge Has system been converted to 134A? Find accumulator silver can on pass side firewall. pull connector off cycling switch jumper comp come on?
Sep 17, 2009 at 4:28 AM
GNAPPI
[quote:fe8b05cd73="Docfixit"]Do you have gagues? if yes check charge Has system been converted to 134A? Find accumulator silver can on pass side firewall. pull connector off cycling switch jumper comp come on?[/quote:fe8b05cd73]
I am not an AC guy, but am pretty good with electric, but I have no idea where relays and fusible links for this car physically are, that's where I need to look I think.
Like I said, both the AC clutch and electric cooling fan work with DC applied directoy, but no other time do they work
Oct 27, 2009 at 7:13 AM
